Great job JVS!
Cheers GSS
A really good job.
But 'I do not understand' cause the decompressor does not work well.
For example in my B5 the decompressor does not have problems even with the minimum set at about 550 RPM.
That's quite interesting. It's not supposed to be like that. You lucky guy
If you bought the bike brand new, did it have any decomp clacking before? Any that you can notice below 550? Or when you turn the bike off, do you hear one or two decomp clacks during the final dying power stroke(s) as the engine is shutting down?
What might've happened is that your decomp spring + arm combo was installed in a way such that it is 'tuned' to activate below 550. There is no set procedure or particular setting for the decomp. Each bike is different, however it is supposed to engage below 700RPM. This may vary, some might engage below 900, some 700. Probably quite dependent on the spring within the decomp assembly.
Do you kick-start often, and do you find it difficult? When you reach compression, and as the kick-start lever suddenly stops, is it easy for you to get past this stage? Or it takes a lot of effort? If it takes a lot of effort, then I think your decomp isn't engaging at all. Maybe it was removed/disabled by the previous owner or the dealer (which I'm just assuming). Or, it's just kapoot.
I have noticed that same feeling since I've had the bike, slowing down through the gears, it felt like it was a second or 2 before it would take off again, I changed to a NGK plug and it helped a little.
Could you tell me why do you think that removing it helped? I would be interested to know.
I myself have an NGK plug. Had the BPR6ES for a long time and recently I switched to the BPR6EIX (iridium version). Even with the BPR6ES, it would tend to die sometimes coming to a stop at a corner/turn (rarely).
Imagine this: You're coming to a corner/stop, going from high to low gears. You've gone to first gear now, and you're holding the clutch lever in as you're braking to make a safe turn. As soon as you pull the clutch lever in, the RPMs drop to your idle RPM. The ECU is trying to maintain a certain mixture, and for one of the time periods/pulses (Steve Thackery might be able to elaborate) during that clutch lever pull, the ECU has squirted a bit too much fuel, causing the idle to drop below your actual set idle RPM. This momentarily engages the decomp ever so slightly, and with one clack (decomp being engaged), the engine has suddenly lost some compression and has shut down.
This has happened to me a few times over the young life of the bike. With the decomp out now, even if the idle drops momentarily, there is no sudden loss of compression that can occur, therefore it shouldn't just shut off at a corner or a stop. I was at numerous stops/traffic lights on the weekend, with low idle clutch pulls, and it kept going. Until and unless the idle you've set is terribly low, then that is a different story.
