Hey all,
So to preface this, I have done some reading on successful carb settings with the BS29 that comes with the AVL bikes. I get the gist of carb tuning, and what settings will affect which part of the throttle opening.
Biggest problem right now is a bit extreme-- getting engine backfires through the carburetor (and occasionally the kickstarter), sometimes severe enough to pop the carb right off it's rubber mounting flange. That's pretty alarming, particularly when it happens on the street
Before I go to much further, here's my current setup--
BS 29 Carburetor, stock engine, with a K&N cone filter and free-flowing exhaust-- all the emissions skunkworks have been removed or blanked-off by the P.O.
Main Jet: 122.5
Vacuum Slide Needle: Clip on the richest notch, with the spring resting on the washer above the clip, then a shim washer, then the plastic adjuster.
Idle Jet: 17.5
Fuel-Screw: About one full-turn out.
It's worth noting that I've seen some hairline cracks on the rubber mounting boot. I just tried blocking them off with some black electrical tape (yeah yeah, I know), but I'm not sure if that helped.
Having a weird time starting-- bike usually starts on the first kick, but then doesn't want to start back up after I've shut it off. It doesn't seem to want to run at all without the enrichment knob at least halfway out, and has a very poor idle, like the engine is straining to keep going. This even happens with the "choke" (enricher) partway on.
Other than that, seems to run okay. Plug was sooty (rich) the last time I pulled it, which is probably for the best, all things considered. I did notice that the power bogged at WOT during one ride, but I believe that may have had something to do with leaving the enricher on.
So all that said... anyone have any tips or carb settings that might help? I'm pretty well stumped here.
