Sorry, should have said all wet plate batteries. If you have sloshy liquid acid, there should be a vent line. If you have a gel battery or AGM there may not be a vent line. Gel batteries generally have no vent line, but have a hidden vent to let gases out. AGM are totally sealed unless you get to very unhealthy pressure, then there's a release that lets go so the case doesn't pop.
