He pretty much nailed it, except for the usual complaint about vibration. If the vibration bothers you, you are riding it too fast. And vibration always comes through the right grip because of the play between the throttle barrel and handlebar. Foam grips can help, but if you think the Enfield's vibration is bad, spend a few hundred miles on an inline four sport bike. They numb your hand so badly that you lose all feeling in it, which I consider downright dangerous. Also, they were meant to be ridden fast, the Enfield was NOT. Otherwise, seems like he pretty much gets it.
