Drain the oil (remove all plugs under crank case) into a clean pan and pull the oil filter. See what comes out. And measure how much oil was in there. Have you pulled the timing cover yet? Pull it if not and have a loo. When your rear tire locked up how were you running the bike? Easy pace, pulling a hill, full throttle acceleration, etc? When was the last time you changed the oil.
