You have to start looking deeper.
Release the clutch, and see if the piston can be pushed down and pulled up by hand pressure.
If the engine is frozen up with the head and barrel off, then it is locked up mechanically. If the primary side looks good, then take off the timing cover, and see if the cam gears are locked up, or the lifter has failed and locked things up. If that all looks good, then it is in the crank/bearing area, and the engine has to come out and cases split to see.
