Since the GT's motor is so thoroughly from the last century as it was on India's roads, it's inadequate and ill suited for totally fitting in among today's evolved designs on the super highways of the 21st century in other parts of the world.
I don't think you know much about the history of the Bullet engine. The 1950s design was abandoned in the early 2000s and replaced by a substantially re-engineered engine developed by AVL. It also had a totally different gearbox designed by Reading University in the UK. The engine and gearbox were deliberately designed to look like the originals, but not a single component is interchangeable with the original 1950s "iron barrel" engine.
This was re-engineered once again in the late 2000s to give us the modern-day UCE engine. The crankshaft is the same as the AVL (and I think the gearbox, too?), but everything else is completely different and MUCH better. In fact, it is a more recent design than many engines found to this day in Japanese bikes.
Thanks to a massively improved lubrication system, steel conrod and beefed up bottom end, it's a pretty strong engine. There are hardly any reports of UCE engines blowing up or wearing out, despite what you assert, and no recognised mechanical weaknesses which result in regular failures.
Having said that, I am VERY disappointed by the quality of both the design and the manufacture. That noisy valve gear should NEVER have made it into production (bearing in mind every part of the valve gear is brand new and it uses hydraulic lifters). I've just ordered and received a pair of pushrods for my own UCE, and they are terrible!! The "spherical" blob at the top isn't spherical and wobbles when you spin the pushrod in your hands. Ditto the spherical hollow at the bottom - it isn't round, and it's very obvious to the eye. The aluminium shaft is covered in deep scratches which have been partially hidden by what looks like a quick rub over with 80-grit wet-and-dry.
You could argue that none of this matters and the pushrods will work just fine like that. To me, it just shows a really disappointing approach to manufacturing quality which I think should have been sorted out when the new UCE engine was being developed. Even the rubbish we Brits were turning out in the 50s and 60s were better made than this.
Uncle Billy - do you have any evidence to back up your assertions? A list of blown-up UCE engines, for example?
