Okay, now leave all that stuff right there, and don't turn the engine anymore now.
Now, take the distributor cover off, and have a look at your Boyer Mk4 ignition.
See if the unit is lined up with the magnet at the trigger coil, just like they tell you to set it up when you install it new.
If it looks like that, then go ahead and do the check that they tell you to be sure that it is timed right.
If it doesn't look like that, then let me know, and I'll let you know what to do.
