You can get aftermarket centerstands for KLRs and Suzuki DRs. Because these bikes are so tall, many people lower them to make them easier to ride. Of the 3 companies that make aftermarket stands, at least for the KLR, they all offer shorter stands for lowered bikes. Your on your own with the sidestand. I had a 1985 1200LTD Goldwing, with worn out rear air shocks that wouldn't hold air, so it sat low. Nearly impossible to put on the centerstand, and on the sidestand it sat so vertical it would almost fall over on the right side. New Progressive air shocks solved those problems. To bad they didn't fix all the rest of that bikes problems.
