Im having a weird year with my carb.
1st. Blew the air adjust screw out of the carb (same day I laid it down). Got a new one all was good.
2nd. Went to ride today, and it started, but wont hold idle.. then I couldnt start it at all. Thought it was electrical, so I tore it down... no problems and fat spark at the plug. Ripped apart the carb and found there is NO AIR JET (No. 53 on the sudco diagram http://www.sudco.com/Diagrams323728/exptm.gif). WTF. Cant find it... Its not in the airbox, nor bowl. Wondering if the intake took it. Looked inside at the intake value; nope. Looked in thru the plug opening; nada. Looked thru exhaust; zip. Where the hell did it go and how did it get out??
Anyone have a similar experience?
Edit: Looking at the tm 32 specs. Does this carb even come with an air jet? I doubting myself now.
I only just read this this morning (Thursday 8 AM). What have you figured out & what's the latest?
I would go down right now & look at mine if you need me to. If you don't, fine, because my hands (& everything else) hurt
As far as I remember, Part #53 is in there on mine.
How do you think your air screw came out? Anything new on that?
Mine is running great except I still haven't hit that sweet spot to where I can kickstart it first thing in the morning. It just refuses. Once it's been started & running once (with the ES) then I can kick it 1st or 2nd kick every time & it drops into a perfect, hands off (orgasmickly thumping) idle.
Of course, our bikes don't compare totally because of the ACE headwork on mine, but our experiences with the TM-32 seem similar. She can be a touchy bitch. I think part of my initial-kick-start-in-the-morning problem could very well be because of the increased CR which is 9.8:1 on mine & I will just have to live with it. It starts instantly cold with the ES so what am I complaining about?
The friggin' thing is amazing otherwise. Getting to 60mph is smooth as silk & very quick & 60 is perfectly comfortable feeling in 4th & unbelievably comfortable in 5th.
