Did 120 miles today, takes a while when you're limited to 30-40MPH and have to stop all the time to cool the motor down BUT that's breaking in. I now have a major complaint about this bike...why'd I wait so long to buy it? It's a hoot to putt around on and everywhere I stopped people wanted to know all about it. I gave it a bit more gas than last ride as it seemed to want it and I found it pulls a lot better than I thought it would. I did get over 45MPH once...with the clutch in on a long downhill just coasting, you know the type I mean the ones with the "Truckers Use Lower Gears Steep Hill" sign.
I topped off the tank on the way home and checked mileage just over 80MPG? Can that be right? I know I'm just putting along but that's just a sip.
I did adjust idle up a bit as there was a loud clacking sound coming from the top end that went away with just a touch of gas so I thought Auto Compression release is kicking in it's turning so slow! I gave it maybe a 1/8 turn and the clacking stopped, plus it wanted to bog down and die unless I blipped the throttle and now it's maybe 50 RPM higher and idles nicely. I have to get a automotive Multimeter with a tach, HF as one for about $30.00.
Here's a photo with the 7" headlight and Bullet Blinkers on I took today, sorry I used my phone.
Bad new? Back to rainy weather starting tomorrow for the rest of the week. AT this rate I'll have it broken in by Christmas!
