Hi, starts good, idles pretty good, runs good at more open throttle. It's when the throttle is just open (less than 1/8) it sputters or misses no matter what gear. I have adapted my riding/throttle technique to avoid being embarrassed when riding past people. It's 59 Indian Chief, 30 pilot jet. It has HD mufflers and a stock air filter. When I set the points and timing I noticed I had rotated the distributor to it's max counterclockwise in effort to have the points just open at (what was it, 18 degrees?)BTDC. It seems like I need to turn it farther to be correct. I have the air screw around half to 1 turn out and it seems like I might still be a little lean. Question is, should I be looking at ignition or carb at this point. I can't seem to adjust either any further to get improvement. Thanks.
