Dear All,
I have installed LEDs as turn signals on my Bullet Electra motorcycle and if i switched on one side turn signal indicator light, power will back feed across the indicator light and all turn signals will flash at once. could you pls explain how to install the Diode Kit to avoid such situation...if any same subject was discussed earlier, pls provide the reference as well. Thanks
