Author Topic: Personal Messages  (Read 3405 times)
on: June 23, 2015, 05:44:18 am
Has anyone figured out how to see all of the comments in a Private Message at one time this site?
I get a PM from someone and I answer it.  The computer tells me I sent my answer but I can't see it to verify I sent what I really meant to send.
Then, if the person sends me back an answer or adds another question, I can see what he just wrote but I still can't see the comments I had previously made so I have to rely on my "mind like a trap" memory to remember what I said.
Of course, that can lead to all sorts of fun.
Anyway, does anyone here know how to set something in the PM area so I can see all of the comments, both his and mine, all at once?
It might look like this:
Sender: What did you use to get rid of the problem?
Me:  A shovel.
Sender: How big?  The pile is too big for my wives little garden trowel.
Me: It was smaller than a snow shovel.  I guess it was about the size you would use for digging a normal hole.
Speaking of holes, I also dug one of those to dump the offending pile into.
Sender:  That's a good idea.  I never realized a German Shepard could make such a big pile of dog crap before we got Pee Wee and he's only about 65 pounds.  I may need a snow shovel by the time he's full grown.
Me:  Snow shovels and dog crap can throw your back out.  Better get one of those garden tractors with the plow on the front. :)
Reply #1 on: June 23, 2015, 10:43:56 am
Jim - sounds like PM's are the least of your worries!  ;)
As far as I know, PM's work just like regular threads on the forum... you can "quote" a post, but it will only include the most recent text - previous quotes get left behind.  If you want running quotes of multiple posts, you've gotta copy and paste between "quote" tags manually.  I think...
Reply #2 on: June 23, 2015, 01:16:28 pm
I generally just quote what the other person said, and hope they do it back.  Otherwise, you can always click on the "Save A Copy In My Inbox" before you click send, and it will send a copy to yourself as well.
Reply #3 on: June 23, 2015, 10:41:49 pm
Thanks for the suggestion.
I guess I'll start grabbing the senders post and pasting it into my reply and then hit the Save a Copy button.
It does sound like a pita though.
Reply #4 on: June 27, 2015, 10:55:19 pm
The only way around it is each person quote every response every time, and then it will show up as an actual conversation in your inbox.
Brother Rhett
Reply #5 on: July 26, 2015, 11:45:35 pm
When you're writing a new personal message, there should be an option under the message entry box that says "Save a copy to my outbox".
If you check that box, you'll be able to see a copy your message in "Sent Items" later. I don't know why that's not the default behavior, honestly... but that's how it's done in SMF.
-RW
Reply #6 on: July 27, 2015, 12:15:21 am
Thanks.  I'll give it a try next time. :)
