The rubber sole of my riding boots started to peel off. Cleaned the surfaces with sand paper and then with rubbing alcohol. Applied thin layer of Gorilla Glue. Pressed them together. Clamped surfaces tight with Duct Tape for overnight. Glue expands 3 times as it dries up, so a little bit goes a long way.
Pleased to see that the sole is permanently fixed to the boot. The glue has hardened into a pale yellowish solid rock. It is water proof. Holding better than I had expected.
