I think that First Service should start with 60 points check list of
Pre-Delivery Inspection List of Royal Enfield. It has torques for certain nuts/bolts.
The second document
First Service List of Royal Enfield in India has 22 check points.
The points from second document such as Washing and Cleaning the motorcycle
, that are missing in the
Pre-Delivery Check List, should be added.
Besides these two combined lists, add other check points based on our riding experience here in USA but are not mentioned in either list.
These are - disconnect the side-stand cut off switch, change the spark plug to NGK, change the fork oil, activate headlight switch, replace battery to AGM, replace chain etc. Some of them may not be necessary but it helps to know what are the possible points to keep in mind. Something you may need to do at a later stage.
One thing that has been emphasized but I may repeat is Tighten EVERY Nut, Screw, Bolt, anything that holds two pieces together, anything that your eyes can see and even those which are hiding behind something. I mean who would think that the screws holding the turn signal lens can also loosen
, but RE has a way of loosening anything.
Two official lists from RE India are attached here as pdfs.
Print and give the lists to the dealer and ask him to go over each point or you may go over yourself if doing your own service.
