Author Topic: First post - Fuel pump whine, MIL on, won't start  (Read 6097 times)
nevernotriding
on: June 16, 2015, 04:02:11 pm
Hi there,
First post here, having an issue with my 2011 Bullet EFI. I turned on the ignition for the first time after winter with a charged battery, and it fired right up. The next time I tried it, the pump whines and doesn't stop, the MIL is on. I replaced the battery, it fired right up. Went to go for a ride the next day and the issue is happening again. I am thinking the fuel pump filter is clogged or something and is not allowing the pump to get fuel to the engine. Anyone have this problem before?
suitcasejefferson
Reply #1 on: June 16, 2015, 05:07:20 pm
Could be the pump is plugged up or not priming for some other reason. It could be a pressure sensor, or it could be the main ECU. Or it could just be a bad electrical connection somewhere. For some reason, Enfield painted the inside of the tank, the paint flakes off, and plugs up the fuel pump filter, even as big as it is. I have no idea why anyone would paint the INSIDE of a gas tank, which is immersed in gasoline/ethanol on a constant basis.
nevernotriding
Reply #2 on: June 16, 2015, 05:37:12 pm
From reading posts here, that's what I am going to be checking first - I checked all the connections that I could see and everything looks ok. Sure am hoping it's not the ECU, that seems unlikely.
gremlin
Reply #3 on: June 16, 2015, 06:05:03 pm
sure does sound like a suction filter trouble.
Is the tank full?
1996 Trophy 1200
2009 Hyosung GV250
2011 RE B5
nevernotriding
Reply #4 on: June 16, 2015, 06:09:01 pm
tank is full - although not for long. I'll be in my shop tomorrow to take off the tank and check out the pump.
gremlin
Reply #5 on: June 16, 2015, 06:16:10 pm
what code flash do you get when you jumper the test-point?
1996 Trophy 1200
2009 Hyosung GV250
2011 RE B5
nevernotriding
Reply #6 on: June 16, 2015, 06:37:15 pm
that's the thing - I'm not getting a fault code.
pmanaz1973
Reply #7 on: June 16, 2015, 06:39:17 pm
Could excessive water in the fuel cause this?  Either way, post pictures of your fuel pump/filter removal and cleaning if you go that route.
1984 XL350R
1991 XR250L
1976 Harley XLH 1000
1993 CBR 600
1976 Norton Commando 850
1972 BMW R75/5
2014 Royal Enfield C5
nevernotriding
Reply #8 on: June 16, 2015, 06:47:39 pm
That could be the problem - where I live, we get gas once a year, when the tanks start to run dry, water in the gas. I'll be filtering all my gas from now on.
thanks for the replies - I'll post pics of the process and report back.
Reply #9 on: June 16, 2015, 08:03:48 pm
Although the fuel pump is supposed to shut off when the system reaches about 40 psi, it is possible that the pump pressure sensing switch is inoperative.
Except for the extra electrical power drain, I don't know that this condition is really that bad although it will tend to cause extra wear on the pump.
When you see your dealer, tell him about the problem.
He should be able to test the pump and advise you about the best course of action.
Hopefully, it is something easily fixed.  Those fuel pumps cost a LOT of money.
Reply #10 on: June 16, 2015, 08:39:11 pm
To be clear: when you switch the ignition and kill-switch on, the fuel pump whines to pressurize the system, but it won't shut off?  And - the MIL doesn't turn off?
If that's correct, I wonder if the fuel pump is the problem...
nevernotriding
Reply #11 on: June 16, 2015, 09:31:54 pm
that's right.
either way, I am pulling the pump out tomorrow, so hopefully this will become clearer then.
Bulletman
  • 2011 - C5 Classic Black
Reply #12 on: June 16, 2015, 10:57:37 pm
Fuel pump has a plastic nozzle end to it, which connects to the rubber fuel hose, be very careful undoing that, it breaks easily, been there done that >:(
As "Arizoni" said above the pumps are A LOT of money
"A Blast from my Past"
Black C5 2011
gremlin
Reply #13 on: June 17, 2015, 09:12:29 am
apply a ground to pin 20 of your engine controller (there is a connector for this)  and count the flashes of your MIL
1996 Trophy 1200
2009 Hyosung GV250
2011 RE B5
longstrokeclassic
Reply #14 on: June 17, 2015, 03:35:10 pm
If there's enough room it sounds like a Quick Release Fuel Line Coupler would pay for itself from day one.
Never underestimate the value of improved combustion efficiency and reducing parasitic engine and rolling chassis losses.
