Keven
As you say the leak seems to be around the crankshaft I will assume you are looking at the cap on the right hand side of the motorcycle that is in line with it.
This cap (oil plug) is actually the part that delivers oil from the oil pump into the crankshaft. From there, the oil travels thru drilled passages to lubricate the connecting rod bearing.
As the oil is under some pressure, any small leak in the gasket (Hitchcock calls it a washer) under the cap will leak down the side of the engine.
If this guess is correct, remove the cap and examine the gasket (washer). If it is in good condition, apply a thin coating of a oil resistant gasket seal like Permatex Ultra Black to both sides of it and reinstall the cap.
http://www.all-spec.com/products/82180.html?gclid=CNj43rqdlcYCFUprfgodT7YAIQThat should fix the leak while it leaves the cap easy to remove at some future time.
