Author Topic: Which size/type rear chain?  (Read 1729 times)
capt.logs
on: June 15, 2015, 09:12:51 pm
Have a pre 98 Indian 500 with a 5 speed gear box conversion.  Has a 15" rear tire and am putting a 21 tooth front sprocket on.  What type chain do I need? 520, 530?  I know I need 100 pitch but just don't what type of chain.  Thanks
=Jason-
Reply #1 on: June 15, 2015, 11:25:36 pm
The safest bet is to measure the thickness of the sprocket.
I'm betting it is somewhere around 5/16 to 3/8 of an inch thick.  (That's .312 to .375 inches (8-9.5mm) thick.
The second number in a chain size is the width of the chain rollers given in 1/8 inch incriments.
That makes a 520 chain roller 2/8 or 1/4 inch wide (.250).
A 530 chain roller is 3/8 of an inch wide (.375 inches ),
Even back in the 1950's, Royal Enfield Bullets, BSA's, Triumphs, Nortons, Matchless etc all used the 530 chain.
lomax
Reply #2 on: October 14, 2016, 06:49:27 pm
Does the bike have room for a 530 O-ring or X-ring chain or does it have to have a non sealed standard chain ?
84 R100RS LE,14 Ducati MTSGT,14 Hyperstrada, 73 850 Commando, 78 CT90, 14 Ural, 74 Eldorado police, 64 R50/2, 13 TR650, 01 DRZ400E, 94 900SS/CR, 01 200EXC, 15 RE Classic Chrome https://lomaxcm.smugmug.com/
heloego
Reply #3 on: October 20, 2016, 08:46:46 am
I currently have 530 O-ring chains on both the C5 and the ElectraX AVL.
Our host carries a 101 link RK X-Ring chain for a very reasonable price.
« Last Edit: November 07, 2016, 09:11:13 am by heloego »
'12 C5 Classic
