Hi is it an indian/early frame, or a post 56 cradle type ?. I ask because of clearance around the top of the engine, when I was messing around in the workshop a few weeks back there doesn't appear to be enough clearance for the Interceptor engines in the Indian/early frames so this would suit a Trailblazer better. If on the other hand it is a late Reditch frame, I would be careful as the shorter wheelbase could make the bike very twitchy, you could use a later Interceptor swing arm which is longer to steady things. The extra brackets on the rear of the gearbox are supposed to fit all frames so this shouldn't be a problem. Just my thoughts, it should be a straightforward build using over the counter parts.
