No comment on your list being correct. I am using all LED's everywhere on my G5 deluxe, except 7" headlight bulb & my 2 bar end directional signals. I pulled out my old bulbs, got the #s off them & purchased my LED's all on Ebay, from American vendors at a huge savings. be sure to use the same color bulb as the lens you are putting it behind. I use a RED 1157 tail light LED bulb.
I have just completed putting all LED's in my URAL with the exception of directionals. My Ural Headlight & Spotlights are also all LED. The headlight runs a $10.35 H4 LED with a magnified projector. The 7"headlight reflector itself is diamond cut, with a magnifying projector lens inside the clear 7" lens. Enclosing photos of my LED Headlight & spots. The blue light is my (always on) daytime running pilot. when I turn on the headlight the full array comes on.
