If your getting that sort of reading on your meter with only one test wire connected, take a look outside. Look for a large, black, silent helicopter hovering over your house.
Also it's possible you might see a large glowing disk like object hovering overhead.
They often emit beams of light in various directions and they can streak off into the distance, totally vanishing in less than a few seconds.
If either of these things are seen, you are in great danger,
Get a large roll of aluminum foil and cover your head with it. A stainless steel pot will also work if you don't have any aluminum foil.
