you are all correct. i checked it with the multimeter.all this time i didn't know the12VDC from the points being closed was going all the way through the kill switch and down to the primary of the coil.
that explains why, one time i was trying to start the bike but the ammeter was not deflecting. i looked in the trouble shooting guide and one of the first things to check was the kill switch. and sure enough it was in the kill position.
so, if i wanted to keep the kill switch working all i would need to do is feed the red wire from the module the the same connection the point went to. then it would feed through the kill switch to the coil.
but i think i will just connect it directly to the coil to minimize any resistance from the long thin wire.
thanks for the help
