That's tragic.
Could your primary issue have contributed to the bottom end bust ?
Also, 2000 is a bit extreme. You sure about that ?
It is doubtful that anything in the primary would bust up the bottom end and piston.
Basically, there was a mix of products such as the heavy Wossner 535 piston, the new Hitchcock UCE cams, and our ported OEM UCE head, and an early PCV with altered/AutoTuned maps, and a free flow kit.
All on a middle-aged bottom end, and tuning in progress, seeing some higher end of the rpm scale.
No word on what the actual compression pressure was with this arrangement, but I know it was high because of the flattop 535 piston, and I don't have any real specs on the Hitchcock cams except for the most basic open/close figures.
So, the speculation is wide open for what may have happened.
If I was to take a gut-feeling guess, I would say that the Wossner piston was too heavy for the higher rpms, and the compression with that 535 displacement flat-top piston and the Hitchcock cam timing, was probably too high for the fuel, and that the combo of heavy piston and high compression(possibly with some detonation occurring during the process), on a middle-aged engine a few years old, was probably the recipe that did it in. That's just an educated guess, based on what I know about the piston, and how Hitchcock cam designs have been early IVC and high cylinder pressure types in the past.
