BW, this sounds and looks fantastic! Now I want to do this with my 500. I am thinking I could use my standard 500 head, 500 alloy barrel and 84mm piston, but my calculations show that I need a 63mm stroke crank, or 59mm if I use the 87mm forged piston.
Is such a crank assembly available from the Redditch "parts bin" or is this a special that you have made?
I realise that there are many other factors to be addressed , such as achieving a high compression ratio with the reduced stroke, and cam profile/timing, but I would like to address the fundamental crank issue first and build from there.
