Just out of curiosity, what controls are where on this bike - clutch, brake (front and back) throttle, advance and retard, etc. I'd love to be able to learn how to ride such a machine.
Not having seen it yet and got a detailed idea of where the controls are however I do know the following so far:
Left hand handle bar is decompression lever and clutch and I think the choke is there.
Right hand bar is front brake, throttle and advance/retard lever. There are some that say you only need retard for starting and low speed running but there are also those who advocate using it at varying loads to get the optimum combustion.
Left foot doesn't do anything.
Right foot is the back brake
Gear change is on the right hand side of the tank so don't change gear if you need to use the front brake, adjust the advance/retard lever or operate the throttle! I think there are three gears but I don't know the layout as yet.
It reminds me of the old idea of tapping yourself on the head with one hand while you rotate the other hand around your stomach. If you can do that then you may be in with a chance of riding one of these!
