Thanks guys! Just to keep the discussion going...
The contacts Headlight Lamp are very precarious and space is very limited.
This causes a contact with the speedometer cable and the positive goes to ground, creating a lot of heat.
I have completely redone the wiring of the lamp for just this reason.
Your cables are rusted precocemenet because of the heat that has developed from contact with the positive lead of the lamp.
The new models have the ring of light longer and therefore more distant from the speedometer cable.
I'm not quite sure why a live wire would short electrically against a plastic cable covering, but obviously something happened. My photo of the headlight isn't at a good angle to show the three wires in relation to each other... they're straight and not able to touch each other, anyway. You can see how the wires are bent sharply just next to the connectors, though, which suggests they're wedged tightly against other bits in the nacelle. They've looked just like this from day 1. Do you happen to have a photo of what you did to re-wire your light? I see another visit to my local auto-parts store in my near future...
Unfortunately caricabasso has hit the nail squarely on the head. The short has generated enough heat to liquefy the plastic lining inside the throttle cable which has solidified around the inner cable seizeing it solid. The discolouration on the blue feed wire insulator sheath identifies this as the source of the short. It has been dislodged at some point leaving an exposed live wire when the main beam is on. Both of your throttle cables are dead centre right behind the headlamp bulb. The speedo cable situated behind them picked up a little heat off the throttle cable at the same time.
If this is what happened, then it could explain why the cable is seized. Still, it takes more than an exposed wire to make a short and create heat. The wire has to touch something conductive to ground, and I wouldn't have guessed that a plastic cable housing would do the trick. Unless the housing was already damaged and the metal coil inside was exposed to the headlight wire - and I just never noticed it - and the short was just bad enough to cause heat in that location, but not blow a fuse. Makes me question the wiring and the effectiveness of the fuses - this could have set my bike on fire!
+1 - Perfect explanation of what may have really happened.
@ Mattsz:
Your nacelle looks cleaner than my G5, which has lots of wires all over. But in my G5 the throttle cables are WAY BACK in the nacelle, farther away from headlamp connectors than your B5. There are wires in front of throttle cables that block their contact to the back side of headlamp.
Just curious to know if you had re-routed the throttle cables at some point or brought them in front of speedometer cable ? Or you just moved them to take good picture ?
Singh, maybe this is an argument in favor of the spider's nest (
)? With all the loose wires, it's easier to move them around and get them out of the way of the headlight? With everything "cleaned up" and bunched together like on the newer bikes, it's hard to make room if you need some. Those rubber shrouds, especially the one on the right in my photos, make it very difficult to access those connectors - there's very little play in any of the wires there.
The layout of everything in the second pic of my post above is exactly how it came from the factory (the third pic was taken while I was removing the cables). I've had the speedo out before, but I left the speedo cable in place, and I was very careful to make sure everything remained as exactly like the original as I could, assuming it was the best way. Maybe the 7" headlight protrudes further into the nacelle than the OEM smaller light? Anyway, I will definitely look at re-routing the new throttle cables!
Are both the headlight filaments operating properly?
Yes, they were. No obvious signs of trouble. Both lights worked properly, I noticed no funny smells or smoke while the bike warmed up, the battery has remained charged well...
