I have a relatively low tolerance for vibration so I was thinking about how to reduce the vibration felt through the handlebars of my Royal Enfield. One thing I tried was to install a reinforced rubber washer between the engine head-brace and the frame at the front seat bolt. While torquing the bolt to 25 NM does squish the washer quite a bit, at least it didn't pop out and it may have made a slight reduction in vibration. I really don't know because at the same time I installed a set of Original Grip Puppies on my handlebar grips. That made a noticeable reduction in handlebar vibration.
The Original Grip Buddies are 1/8” thick foam grip wraps that help cushion the grips, reduce vibration noticeably and increase the diameter of the grips which makes it easier to turn the throttle. They have a rough non-slip surface that helps your gloves provide a more secure grip on the handlebars and have a sticky backing that sticks to the rubber grips. You install them by wrapping the material around your grips and stretching it slightly. The ends are connected by a Velcro strip that provides a secure attachment by holding the stretched material in place. The Grip Buddies can be removed at any time and relocated to another motorcycle, or their position can be readjusted should you want to move the seam to a different spot. Ideally, you want the seam to be in a location that can not be felt by your fingers when griping the throttle or left bar and I found that locating the seam at the bottom of the grips, about 20 degrees toward the rear, seemed to work for me. The Puppies that I used on the Enfield were in place on my BMW for the previous 5 years. I just peeled them off the BMW and installed them on the RE. The entire process took about 2 minutes.
The Original Grip Buddies are relatively expensive for what you get. They cost $25 a pair, but are well made, were designed to fit BMW grips, but work just fine on the Enfield. You can learn more about this product at: info@originalgripbuddies.com. The company is located in Saratoga Springs, NY. I bought my pair from Adventure Designs (
www.AdvDesigns.com), which is located not far from where I live. No doubt they are available from other motorcycle accessory stores, also. If the hard grips and/or vibration are an irritation to you, I can recommend this product as a solution that works well and beats trying to add another cylinder.
