A good part of the reason I let my rear tire go unchanged for so many miles is I didn't have a good way to jack up the motorcycle so I could get the wheel off.
I didn't have $300+ dollars to spend on a fancy motorcycle lift and besides, I don’t have anyplace to store one.
Most of the other lifts need to have both wheels resting on them so that won’t work worth a damn if I wanted to remove one of the wheels.
Obviously, a little thought was needed here.
I noticed that when the center stand is in the “up” position, it is still a sturdy bit of structure and the stop keeps it from moving up further upward.
The legs of the center stand are also big enough that they won’t bend with just the 400 pound weight of the motorcycle so I figured it would work to hold up the motorcycle if I came up with a cross-ways piece that was easily attached to it..
Buying a length of 1 1/4 inch square tubing about 2 feet long, two 3" C clamps, two 2" C clamps and one scissors screw jack to go with the scissors screw jack out of my Miata, I was in business.
Clamping the square tubing to the bottom of the folded center stand, just forward of the two springs with the two 3" C clamps seemed sturdy enough so I blocked the front wheel with bricks to keep the motorcycle from moving and put the jacks under the ends of the tubing.
Being somewhat paranoid, I also used the 2" C clamps to secure the tops of both jacks to the tubing so they couldn't slip off.
My first attempt to lift the motorcycle quickly showed me that the side to side stability was a problem. The slightest sideways push on the motorcycle caused the jacks to move dangerously with a real possibility that they could let the motorcycle fall so I lowered it back to the ground and turned one of the jacks so the base was cross-ways (90° ) to the bike.
Turning first one jacks screw and then the other to raise the bike somewhat evenly, the motorcycle was. soon sitting with the rear tire a good 3 inches off of the ground and I still had over 50 percent of the jack height to go if I needed it.
The cross-ways jack did a good job of keeping the bike from moving sideways too easily and the fore/aft positioned jack provided a little rigidity in that direction.
I do recommend blocking the front tire though.
I didn't try it but a piece of 1 inch steel pipe could be used in place of the square tubing I used but if you use this, make damn sure it is securely clamped to the center stand legs and to the jacks.
It will try to roll when the motorcycle is being lifted and if it does, the whole thing could come crashing down.
