Do you recommend not to use foam filter on EFI bike, Any particular reason? Please enlighten me.
Regards
Mandar
My suggestions come from 27 years of working as an ASE certified mechanic/technician, amateur drag racer (cars) and lifelong motorcycle rider, both street and dirt. I have used a lot of oiled foam filters on dirt bikes, my Yamaha XT225 has one. Even riding it all day in the dusty AZ desert, nothing has ever gotten through one. The outside will become so caked up with a mixture of dirt and oil, to the point where it falls off in chunks into the bottom of the airbox. I remove, clean, reoil, and reinstall mine after just a few hours of riding in conditions like that. An oiled foam filter can be used on any kind of bike, carbed or EFI. On a carbed engine, a change in the air filter or the airbox will cause a change in the air/fuel ratio at all engine speeds. If it is off far enough, the carb will need rejetting to compensate. EFI can compensate on it's own, but it's range is very limited. And if you need to make a large adjustment, unlike a carb, you will need some very expensive electronic parts, like the Power Commander.
As for paper air filters, they work just fine, my main problem is that they cannot be cleaned. I considered going from an XT225 to an XT250, and the main thing thing that made me decide not to is because the XT250 uses a paper air filter. Fine for the road, but they cannot be cleaned, and a single day of riding in the off road conditions I ride in would pretty much ruin one. They are not cheap.
IMO, stay away from anything advertised as "high flow" If it flows more air, it will flow more dirt as well. The K&N filter is notorious for this. It is neither foam nor paper, but some kind of gauze. You can see right through it. It is supposed to be cleaned and resprayed with K&N's very expensive cleaner, and some sticky stuff. But even done as per the instructions, it is still a very poor filter.
As for the "more air is better" thing, it can be, but you have to retune the carb or EFI to keep the air/fuel mixture right. Otherwise the engine will run lean, it will have poor performance, and it will overheat. And any performance increase you get with a RE just by modifying the carb/EFI, and air filter will not be enough to notice.
I don't race my bike, and in fact don't even ride it over 60 mph. To me it is just a very enjoyable cruiser, an old fashioned bike to enjoy riding in the slow lane.
I also believe that if you could increase the power of a stock RE engine enough to make any substantial difference, you would drastically shorten the longevity and reliability of the engine. I'm not saying the performance cannot be increased without destroying the engine (ACE is in the business) but it is going to take a lot more than just a few bolt on parts.
I like mine just the way it is, I have owned bikes that would top 150 mph. But I am not a roadracer, and trying to ride that fast on the street will cost you your license real quick (if you don't get killed first)
