my 05 Bullet
37 Guests, 2 Users
B5 Ben, Ducati Scotty
February 11, 2016, 01:08:16 am
Author Topic: How much back preasure?  (Read 1770 times)
luoma
« on: August 09, 2007, 09:23:29 pm »
I have the classic exhaust from the CMW performance kit and am thinking about drilling out the baffle for more noise. I like a good loud bark out the tail pipe, but am concerned about altering performance in a negative way. I have drilled a few tiny holes already to help lean out the mixure (new carb ran way too rich).
Re: How much back preasure?
« Reply #1 on: August 09, 2007, 10:46:51 pm »
Have your way with it. Drilling out the baffle will increase flow some and may in fact be a good thing. The key is to make sure that you re-jet the carb when you have settled on a configuration
luoma
« Reply #2 on: August 10, 2007, 05:55:47 pm »
Thanks, I think I will open it up a bit more. Even with no silencer, these bikes are not as noisy as the custom V-twins roaring up and own the road.
I think I've got the carb just about right. When I first installed it, it was very rich, si I moved the clip on the needle one notch. That seemed to help, but the plug was still a bit sooty, Not enough however to move the needle another notch, so I put a few 1/4" holes in the baffle by going in through the inlet side of the silencer. It's still pretty quiet and the plug is cleaner.
