Author Topic: PAV Question???  (Read 2344 times)
Charro
on: August 08, 2008, 11:25:48 pm
Just picked up a 05 Military. The former owner had installed a British Classic exhaust from CMW. He cut the rubber hose that connected to the old stock header pipe. Leaving the hose open, that connects to the pulse system located in the left tool box. Is that OK?
Can I remove the rest of the system? Do I plug the metal tube that runs from the carb manifold?
My old 03 classic did not have this system so its new to me. According to my Snidal manual all this system does is to, pulse air into the exhaust.
Thanks for your help.
Andy
2014 Royal Enfield C5
2004 Triumph Sprint RS
2004 Triumph Speed Four
2001 Triumph Bonneville
2006 Triumph Scrambler
1998 Triumph Speed Triple
1998 Triumph Daytona
2012 Ural Gear Up
"Tell me what kind of horse you want to ride. I'll tell you what kind of rider you are." (Old Mexican proverb)
The Garbone
  • Shade Tree
  • User Complaints: 22
Reply #1 on: August 08, 2008, 11:53:25 pm
My 07 has the system entirely removed.  I filled the hole in the toolbox grommet with a stainless steal bolt,  as I could not find a solid rubber replacement at the hardware store.   The space in the second tool box is best used for my spare tube and cables IMO.
Gary
57' RE Crusader 250
67' Ford Mustang
74' Catalina 27 "Knot a Clew"
95 RE Ace Clubman 535
01 HD 1200 Custom
07 RE 5spd HaCK
LotusSevenMan
  • ...._[:]@==<
Reply #2 on: August 09, 2008, 01:07:58 am
I got rid of all the PAV stuff in the lhs toolbox.
Left more room to fit the homemade electronic ignition system!
The swich is just a 'crude' ignition interupt that stops the bike starting even if some bar$*"rd jams a screwdriver into the ignition barrel and the white LED on the opposite side is a timing light I built in.
Ducati 916 'L' twin
Charro
Reply #3 on: August 09, 2008, 02:22:44 am
Got it its gone. What did you use to plug the small metal tube at the carb intake manifold.
Andy
2012 Ural Gear Up
LotusSevenMan
  • ...._[:]@==<
Reply #4 on: August 09, 2008, 03:29:12 pm
I found that by giving that vacuum tube takeoff a 'wiggle' you could remove it; turn it back and forth and it just comes out complete.
I then used a suitable self tapping screw with some sealant on it to seal up the hole!
Ducati 916 'L' twin
fredgold52
  • Macomb, IL Flatlands Rule
Reply #5 on: August 11, 2008, 12:09:03 am
The screw like L7M suggests works, so does filling the hole with JB Weld.  Excellent stuff!
