I installed the bulb and took it for a ride last night... I think I may have my wires switched because it seems the 'low beam' is much brighter and higher than the high beam (which looks dim, yellow, and uselessly underpowered). The useful setting on the bulb is great though, and projects much farther than the stock bulb, and from what I remember it's brighter than the Mindra sealed 7" as well.
When parked at a light with the bike running, my ammeter would twitch back and forth from centered to just-slightly-negative (from the bulb's load I imagine). When riding, the ammeter was dead center and wouldn't budge right or left. I imagine this could lead to a decrease in battery charge over time. Fingers crossed it'll start up next time I want to ride (it's kick-only, so not much power is needed. I can also switch the headlight to Off when starting it up to preserve power.
Chuck
