I have an 06 Iron Barrel 5 speed, and so far have all the nuts and bolts loosened to pull the motor, with the exception of the large (20mm?) bolt that runs under the trans case and through the lower part of the bracket for the center stand. It does not appear to actually go into the trans case, but rather, the case has grooves cast into it that the bolt runs through....
for those that have pulled the motor, how did you guys get past this part?
