Ok, then if a taller gear is good for 4mph the max cruising speed would be around 70 (65 is rated as the top all day without a problem speed). The stage 1 performance is good for another 4hp (20% higher output). How will the higher output affect the RPM at speed? Will it lower the RPM needed to go at a certain speed because there is more oomph? I'm not looking for something to set the world on fire here, but I'd like to be comfortable cruising at 70 if possible.
The performance kit should give general power increase. It is not really related to changing rpms, other than possibly giving more power at somewhat higher rpm.
It can help you to more easily cruise at any rpms to reach your goals. But the rpms at road speeds are fixed by the gear train, so using the combination as you outlined would address both halves of the equation.
Reduce rpms with taller gearing.
Make power mods to produce higher hp at lower rpms to help the engine cope with the gearing change.
Free-flow the intake/exhaust to help the engine breathe easier to make more power in the higher rpms, so that it can rev higher with less effort.
The Stage 1 kit, as I understand it, makes some necessary steps in this direction, and so does the 1-tooth larger sprocket. These are modest changes, but will be helpful to move toward your goal, and this combination is a sound approach.
I think cruising speed of 70 mph is more probable than 75 mph with this package..
