Sometime in the summer I will repeat my temperature measurements with and without the PCV. The only flaw in the test was that I changed from the standard catalytic exhaust to the sports exhaust at the same time. I got a 40 degree difference on my regular test loop using a handheld infrared thermometer. This is similar to my 35 degree difference doing a remap on my 2007 Guzzi 1100 Breva, and the Breva retains the standard exhaust system. By far, the biggest benefit to the PCV is the reduction in running temperature. You don't need a thermometer of any sort to notice the difference, you can put your bare hand on the fins for a few seconds before pulling off!
