While waiting for the throttle tube sleeve from RE member solg, I realized the carb is leaking. It's done that before and it was a dirty or stuck float seat. It's a Mickarb VM28. I would like to go ahead and put a new one on of the same type and model. Is there anything I should be aware of before buying? If not mistaken, the main jet on my current carb is 30. Can I get a new Mikuni VM28 and swap out the jet? Or do I buy one that has the proper size jet? Will the flange match up? It's a round side model. Mine has the chock lever not the pull knob.
Thanks,
RV
