Good luck with the 612, it's looking good! My big end in my 500 disintegrated last year, and I rebuilt the engine with an Aplpha roller big end. All good, but when I took the bike on a 50 mile run, it overheated and stopped. The valves were stuck open, because the debris from the big end failure had found its way up into the rocker box and blocked the oil passages to the rocker arms, which were seized in the bearing blocks!
So,a cautionary tale. I have now cleaned out the oil feed pipes and oil ways a few times to make sure it's all gone. Of course, I should have checked this when I rebuilt.
