A wheel-driven generator could be used to power the lights, but the extra load on the drive system would result in less efficiency than simply powering them electrically through the DC/DC converter. The DC/DC converter is a beautiful thing, with a capacity of 400W (way more than I need) and rock steady. It is integrated into the on-board charger, has a very high efficiency and eliminates the need for an extra 12V battery. It also has switched and unswitched outputs, allowing me to activate the lights and drive system using the original key switch and run switch.
I have a few more stats:
Range: 44 miles (actual commute profile).
Fuel economy: $0.01 per mile
My acceleration technique was imperfect and I think I can re-do it for better results, but I measured:
0-20: 2.0 sec
0-30: 3.6 sec
0-40: 5.2 sec
0-50: 7.6 sec
0-60: 11.0 sec
Top speed: 70 mph
Weight: approx 385 lb (bathroom scale method)
Cost of conversion: $4557
I have a few more items to buy to finish it nicely.
I'm building a nice website with detailed information on all the components and the build process. I'll put a link on this thread when it is presentable. I will also include detailed parts, material, cost and vendor info on the website.
