since search program is down, I'll fresh'n up an old topic. 2002 iron barrel, alloy cyl. upgrade runs great. jetted up carb. to 130 main. Been runnin nice n cool, took it to work yesterday, 45 deg F outside, did great till bout 40 mph, quick heat jump, pulled over when it reached 280, just pullin over @ idle the temp started fallin quickly, let it run till it reached 230 deg, took off, two miles later had to do it again. Runs great all the time w/no odd noises, the 280 temp didn't effect the idle or change tappet noise, without the temp guage I'd have nev'r known there was an issue. Any thoughts from anyone that I may be overlooking as to why I've got this issue? It's cold here & I'm still runnin 20/50 multi visc. in the engine.
