I haven't approached the dealer or CMW since getting the bike running.
As it was obviously a defect...heck...stuff happens...I'm hoping I can
be reimbursed for the cost of the head and top end gasket kit.
While a bit of an inconvenience, I had to dig into the top end right away
as the Bullet's my primary mode of transport right now and I couldn't
run the risk of the dealer putting the repair job on "the back burner".
The project did have a benefit. I'll have no trepidations about tearing
the top end down when "decarbonising time" arrives. It'll be a "piece o'
cake". I wasn't kidding when I mentioned, in an earlier post, that I could
probably tear down the top end and reassemble it blindfolded. It's such
a simple and straightforward design! About half the tools I needed were
in the factory tool kit. The rest were at-hand in my toolbox. I'm going to
add them to the roll-up tool kit and have that warm, fuzzy feeling knowing
I have what it takes to tear-down the top end sitting in the compartment
just to the left of my right leg. I'm going to give the bike a good "going over"
and stick all of the tools needed for the job in the tool kit as well. A master link,
a half-link, a roll of electrical tape, a couple of spare sparkplugs, a roll of wire
and some duct tape should complete my "anything goes" contingency kit.
(I used to be a Boy Scout.) There's nothing you can't fix with a roll of wire
and/or duct tape. I had a '61 VW Beetle that had the throttle cable break while
a few miles from home. Because the spring that held the rear deck lid open
was gone when I bought the car, I always carried a 1 x 2 to prop it open when
I worked on the engine. I took my trusty roll of wire and tied one end to the
throttle arm, ran it around a notch I cut in the 1 x 2 with my pocket knife and
tied the other end to the driver door handle. I had some great throttle action
by reaching out the window and pulling a little tension on the wire. I'm
surprised I still remember all the details....the late 60s, early 70s were heady
times....
Ole
