I see a lot of RE riders and prospective riders are overly concerned about the frame weld on my C5 breaking. I am not concerned at all. The reason I posted the info, the photo and the symptoms is to give a heads-up so that, if you experience the same symptoms, you should check out the frame. Not to scare people away. Here is some facts:
1. I ride daily. A 16 mile, one way, commute and some errands. The symptoms were prevalent for a month, but I could not find the source. (The increased engine vibrations and the weird rubbing noise when applying the rear brake.) That is over 500 miles! But Rocinante (my C5's name) held together and travelled quite well. The REs are robust and well put together. Except for one weld in many thousands - tens of thousands - hundreds of thousands - or maybe millions made in 2012 (the year rocinante was manufactured) no other problems of this sort have been reported. The problem was an anomaly. The only one of its kind as far as I know.
2. The only other case (the one that was reported) of a frame weld break was the result of an accident with a kangaroo. If you look at the youtube videos, you will see many riders - especially in India - taking their REs through very rough tracks and roads - at speed - WITH NO PROBLEMS!
3. It was the dealer who found the problem - not me. That should tell you that , on the most part, the RE dealers are very good at their job. Kevin of RE-USA, and Tom and the staff of Southern California Motorcycles are great people!
4. The Royal Enfield establishment stepped up to the plate and made good on the warranty. I'M GETTING A NEW BIKE! Would Honda, Kawasaki, or any of the other brands do the same thing? I hope so...but who knows for now?
Again -- NO WORRIES!!!
ROYAL ENFIELD MAKES GREAT MOTORCYCLES!!!
