Author Topic: Different colour rear springs  (Read 4334 times)
1thump
on: December 16, 2014, 09:44:51 am
im not that into the yellow rear springs. Any suggestions on black replacements?
'14 Continental GT
'15 KTM RC390
'09 CRF230L
JVS
  • I love chicken
GSS
Reply #2 on: December 17, 2014, 02:21:20 am
Hitchcocks sells black replacements in two different stiffness levels.  I am hoping to find chrome ones one of these days.  The OEM shocks are excellent, so no incentive to change the entire unit to something like Hagons.
GSS
2019 Himalayan Snow
Previous REs:
gashousegorilla
Reply #3 on: December 17, 2014, 03:25:57 am
KD5ITM
  • Financial Problem Solver - Life Insurance, Mortgage Protection, Retirement Protection
Reply #4 on: December 17, 2014, 03:39:07 am
the rubber dipping stuff will look like junk in a few years and depending on what color you do, it will probably fade pretty good.
1979 Hurst/Olds W-30 “R” code
1967 Oldsmobile 442 W-30
1964 Volvo B18 544 Sport
1961 Willys Jeep Wagon
AgentX
Reply #5 on: December 22, 2014, 09:18:00 pm
If all you want is black, a local powdercoater can probably do the job cheaply when he does another run of black parts, which is likely he does pretty often.  Prep work would be the biggest part.
Reply #6 on: December 23, 2014, 12:59:11 am
If it's real powder coating it will need to be heated up to about 400 degrees F (200 degrees C.) to cure.
That's bound to screw up any rubber seals or the oil inside the unit.  There might even be a good chance that the hot oil, heated air/gas and weakened seals will end up filling the baking oven with a spray of flammable oil.
AgentX
Reply #7 on: December 23, 2014, 04:31:35 pm
Good god, did you think I meant the whole shock unit?
Springs, man.
Reply #8 on: December 23, 2014, 10:23:33 pm
I'm sure you and the other members here wouldn't do the entire shock unit but, you never know.  ;D
GSS
Reply #9 on: December 24, 2014, 12:57:36 am
You mean I have to remove the shocks from the bike before powder coating?  ??? :(  ;D
Does anyone here have experience with the cheap powder coating stuff they sell at HarborFreight?  I have been tempted to try the stuff on something.
GSS
« Last Edit: December 24, 2014, 01:03:26 am by GSS »
2019 Himalayan Snow
Previous REs:
KD5ITM
Reply #10 on: December 27, 2014, 07:39:32 pm
I use too work at a big time powder coating shop. There's a reason why the cheep stuff is "cheep".
Jellyroll
Reply #11 on: December 30, 2014, 06:41:07 am
If you try that HF kit, I'm sure any responsible manufacturer will note in the instructions that when you bake it at 400 in the oven, you can NEVER use that oven for foods ever. So, go buy a crappy second hand oven and run a 220 extension out to the back yard so the fumes won't kill you. Also, not good to do on a rainy day, or if you watered the lawn. Don't forget your OSHA approved respirator and hazmat suit. And gloves. And booties. You'll want to throw all except the respirator away, and change out the filters while yer at it. Nasty stuff.
You Are
What You Do
When It Counts
GSS
Reply #12 on: January 06, 2015, 03:21:51 am
I ordered replacement black springs in a softer setting from Hitchcocks.  Cheaper than getting new Hagons or messing with powder-coating.....-31F windchill this morning......won't be getting any riding to test the springs for another 3 months  :(
2019 Himalayan Snow
Previous REs:
