A few numbers for folks worried that 5 lb/ft of torque on their rocker arm block nuts might not be enough to hold the block down, here's a formula for calculating the compressive force created by one bolt or stud/nut after torquing it.
F = T/(d x .20) (see below)**, where F = compressive force measured in pounds, T = torque in lb/in***, d = major diameter of thread.
For 5 lb/ft of torque we have 5 X 12 = 60 lb/in
If the thread size is 1/4 inch then d = .250
That gives us 60/(.250) .2 = 60/.050 = 1,200 pounds.
With 4 nuts per block that equals 4 X 1200 = 4,800 pounds.
** The .20 value is for dry, steel threads. For lubricated steel threads use .15
*** Note, the torque must be in lb/in. If you are using pound/foot values, you must multiply the value by 12 to get pound/inch values.
