Drain the oil, run the gas out of carb, drain tank, squirt some oil in cylinder kick it over a few times to spread oil around. Put it up on compression. put it on center stand. Pull the battery. Your done this will keep it ready for years. Cover it if you want to keeps it from getting to dusty. ERC
