kjvelo:
As everyone here knows, I'm a fan of using a torque wrench, especially when tightening steel bolts and plugs into aluminum parts.
Of course it's always a good idea to buy the best brand that you can afford but, even the cheap Harbor Freight torque wrenches are accurate to +/- 2 percent and they only require setting them to the right value before you tighten the nut or bolt.
If you are afraid of Harbor Freight's tools, Sears tools ranks near the top in quality in my opinion.
I've used the bend beam style for years and although they are good, reading the pointers location on the scale can be difficult, especially if one is looking for an accuracy better than the click styles +/- 2 percent.
As for the range, the 0-200 lb/in one maxes out at 16.67 lb/ft. That's just barely more torque than the large oil plug needs. (15 lb/ft)
The 10-150 ft/lb wrench doesn't go down close enough to the small bolts that hold the oil pump pickup screen cover and oil filter cap covers 4 ft/lb torque requirement.
Look around and see if you can't fine a 3/8" drive, 0-75 ft/lb torque wrench that adjusts in 1 ft/lb setting increments.
That will cover 95 percent of all the fasteners on a Royal Enfield.
My "Snap On" torque wrench can't be the only one that has this range available.
If you get a adjustable click style wrench, don't forget to reset it to zero after your finished using it. Leaving it set at some torque value for long periods of time can mess up the spring inside.
As for torque values, the best way to find them is to have a RE Parts Catalog + a RE Service Manual. You need both to find the torque value for a specific bolt, plug or nut.
Lacking those books/DVD's, just ask us for the torque value. One of us will dig it out and post it here on the forum.
PS: If you need a torque value and can't wait for an answer from us you can use this chart I made. It shows torques for metric size fasteners in Lb/in and Lb/ft values.
http://www.enfieldmotorcycles.com/forum/index.php/topic,10638.msg123549.html#msg123549
