Which works best?
Pazons seem to be better than Boyers, but they cost almost as much as PowerArcs
The PowerArc seems to be the most sophisticated, considering you can program it, and it has two switchable curves, but I'm guessing I'll have to buy the coil too? Will it work with the regular Bosch coil that I have?
If so then the PowerArc will be ideal!
We have noticed that the PowerArc has some trouble with kickstarting, and the Boyer starts up much better on the kickstart. We have been able to improve the situation by re-indexing the PowerArc to "think" that it is at TDC, when it is actually a little bit after TDC, thereby retarding the curve slightly. But with all the user reports that I have heard, the Boyer seems to be the most suitable, except for the rev limiter. I have not tried the Pazon, but Royce just got one to replace his Boyer, and he says it's better.
Kevin has tried a British version of the PowerArc that is made for them to their specs, and has programmability, and he found that to work well on his Super Fireball. I can't remember the name of that one.
