I've got something similar going on with my bike, but by choice. I'll explain.
Since I'm very often in stop and go city traffic, the engine is forced to sit at idle quite a lot. For this reason I have the idle circuit set 1/8 to 1/4 (no more) rich for it's cooling effect. Not enough to make the engine die, but enough to slow the revs at idle to just before that point. I make this adjustment seasonally as the average ambient temps rise or fall and with the engine at full running temperature. I use the small slotted air bleed screw for this. In for richer, out for leaner. I then use the large knob (which raises and lowers the slide) to bring the idle back up around 12-1300rpms. A very slight tweak accomplishes this.
Now since I'm already on the rich side, I don't need to use the choke at all in warm weather. In cooler temps (below 50F), on a cold engine, I'll 1, engage the choke and give one full kick through with the ignition OFF and then 2, close the choke, switch on the key and then go for the starting kick. It works every time.
