Desert Storm C5 2012 with Kick Start
February 09, 2016, 05:02:41 pm
Author Topic: Engine Sproket puller  (Read 2382 times)
gemini641
« on: August 07, 2007, 06:43:18 pm »
I'm waiting for this tool from CMW but am considering making one myself since they're currently out of stock...doesn't look too complicated. (See Sprague clutch woes on this board).
Does anyone know the thread diameter of the holes in the sprocket gear? Looks like maybe a 5 or 6 mm bolt but what thread count?
Tom
« Last Edit: August 07, 2007, 09:39:36 pm by gemini641 »
justin_o_guy
Re: Engine Sproket puller
« Reply #1 on: August 07, 2007, 07:01:03 pm »
I have no idea, but if I didnt get an answer pretty quickly I might consider looking around on the bike for a bolt that I could pull that would fit that hole. If you can get one to fit, a trip to the local hardware store might be all you need to solve your problem. If not, then maybe a trip to the store & a small assortment of cheap bolts to try?
« Reply #2 on: August 07, 2007, 09:40:28 pm »
Tom- have you got the clutch hub broke loose yet? Any time I've worked on mine the clutch was the hard one and they both have to come off at the same time. To pull the clutch hub I remove the center plate and springs, then find a socket that is smaller than the shaft and place it under the plate and tighten the 3 bolts equally.... Voila- a puller. the gears on the output shaft have always slid off for me, O sideplay in the primary chain holds it on so you have to remove both at the same time.    - Mike
gemini641
« Reply #3 on: August 07, 2007, 09:47:33 pm »
Mike,
I have the clutch center puller and shouldn't have any trouble getting the plate off. I just assumed that since the bike is new, the output shaft sproket gear will be pressed on pretty tight. I'll try with just the clutch puller and see what happens.
Thanks,
Tom
And thanks, Justin, I may try that if I can't get it off.
scoTTy
« Reply #4 on: August 07, 2007, 10:37:07 pm »
er, why are U doing this ???
FiferWD
  • Happiness is a warm Bullet
« Reply #5 on: August 08, 2007, 01:03:49 pm »
Tom
If you don't mind waiting a day, I can check when I get home.  I happen to have a spare 17 tooth sprocket in my parts bin
Yrs,
Bill
gemini641
Engine sprocket puller
« Reply #6 on: August 09, 2007, 09:27:39 pm »
Thanks, Bill, but I guess I won't need it. CMW shipped the tool yesterday and it should be here Monday.
Tom
