If the higher octane fuel cures the pinging, then you either have higher compression than usual for these engines(for some yet undetermined reason), or you have very crappy regular grade fuel. Or both.
If higher octane fuel doesn't cure it, then it is most probably some kind of pre-ignition issue, most likely caused by a hot spot in the chamber somewhere. But there still would be some possibility for something else to be causing the heat.
Take it one step at a time.
Ah.
That makes sense to me. Oh, how I wish I didn't have nothing but a few busy days of near-freezing temps left for the year!
Meanwhile...
I had a few minutes in the garage today, so I decided to pull the plug and do a quick check.
The plug looks perfect. Using a flashlight and trying to peer into the hole, with the tank still mounted, was fairly futile, but I
could see a little bit as I cranked the piston over with the kick start lever. There's definitely some shiny, bumpy black crud on the piston, but I simply cannot tell any more than that. From what I've seen and heard here, that's not unusual?
I disconnected the power to the fuel pump, and installed my compression gauge. Electric start, wide open throttle, three different times:
160 psi, each time. It only took two strokes of the piston to reach it, third stroke didn't budge the needle any further - I don't know if that's relevant.
A bit high? I don't know is how accurate the gauge is. Maybe I'll hook it up to my air compressor just to see how closely it matches the compressor gauges...
Regarding the auto decomp: when it lifts the exhaust valve, does it lift it enough so that you can see the valve movement, either through the plug hole or through the exhaust manifold?
